Oil Archive (no new posts) An archive of oil related questions and comments.
Engine Oil vs Gear Oil
Old 08-17-2015, 02:29 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
And even though changing every 15 hundred is goid , it will still run hotter.
Not good IMO in daily stop and go
  #132
Old 10-12-2015, 09:56 PM
shortbox's Avatar
shortbox
shortbox is offline
Default SYN-3 versus Conventional 20-50 and Formula+
2006 Streetglide. I used the HD Syn3 in all 3 holes until my cam bearings went out at about 32K. The cam compartment was totally rebuilt using Timken bearings. I then switched to conventional HD 20-50 in the engine and Formula+ in the transmission and primary. The bike now has 91,000 miles on it and have had no oil related problems with engine, primary, or transmission.
On a recent 3500 mile trip I added 8 oz. oil and this about the same amount of oil it used 40K miles ago. I assume there are a lot of good oils out there but I don't see the advantage of trying/using a bunch of different oils when the HD oil works this well.
Shortbox
  #133
Old 11-04-2015, 06:13 PM
y22c's Avatar
y22c
y22c is offline
Originally Posted by CharliesHarley
I have been thinking seriously about going back to regular oil from synthetic because it seems like the hot weather and synthetic (in south Florida) really thins it out and I hear a lot more valve train noise. Same for the primary. I know they say the synthetic run cooler, last longer and lubricates better. But face it I usually change my fluids every 1500 miles. Any thoughts??
Charlie, try Spectro 25w60 in your bike.
I have been using it in my '01 Superglide and my '12 Streetglide.
it is a petroleum oil, but I change every 3-5K.
Everything runs quieter.
I DO NOT run it in my trans or primary, just the engine.
Ken
  #134
Old 11-09-2015, 05:54 PM
farmboy555's Avatar
farmboy555
farmboy555 is offline
Run whatever gives you piece of mind. we overthink the situation. I run Shell Rotella in everything. My big equipment 15000 miles or yearly. Have 900,000 on one cat engine
riding a relic (06-28-2017)
  #135
Old 11-10-2015, 05:33 PM
splattttttt
I live in a city. I put about the same amount of miles on my vehicles per year. Including my bikes.Never dare to go that long between lubes. My vehicles never last that long. And they're mostly runnin on sinthoils.
Maybe I should move to the country. Is it the air?
  #136
Old 09-05-2016, 09:52 AM
Mr. Greenjeans's Avatar
Mr. Greenjeans
Mr. Greenjeans is offline
I have a long history with gear manufacture and design. To make it short and sweet run Gear oil in your Harley transmission. Doesn't matter if it's synthetic or conventional as long as it's gear lube. That's why they make gear lube in the first place. Reason is because gears slide on the gear tooth under rather high pressure. Harley transmission gears are either 10 or 12 diametric pitch, which results in roughly only about 1.2 gear engagement. Or a little over one tooth at a time. Dealers are seeing a lot more transmission repairs these days due to using engine oil. That was never the case before as in the old days we ran gear lube and a Harley transmission could pull a 4 bottom plow, it was and is built that tough.
  #137
Old 05-06-2017, 05:56 PM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
One week ago 5200 miles on a 17 RGU i changed out my SYN3 to tranny oil to Spectro
Platinmum 75w 140. I have read and heard tranny oil makes a difference. After one week with the spectro i have notice a nice differents with my Bike it goes in and out of neutral a lot easier then ever. Also no more clucking from neutral into 1st and a whole better shifting for me. Love the way it's preforming.
  #138
Old 05-06-2017, 07:26 PM
checkers's Avatar
checkers
checkers is offline
PDB, the original post here is 11 yrs old, that's a record for me. I run Syn 20W50 in motor, syn 75w140 in the trans and dino (Rotella) 15w40 in the primary. I have for years, no failures.
  #139
Old 05-07-2017, 09:30 AM
PDB17UltraRG
Checkers thanks for the reply I run Rotella in all my other bikes love the stuff myself. Just a little hesitant to run it in my 17 RGU M8 motor yet. But a good tranny oil is worth the money
  #140
Old 05-07-2017, 09:34 AM
splattttttt
@ checker; have you ever run synth lube in primary? If not? Than why?
Do you consider the primary a least troublesome section of the system?
Quick Reply: Engine Oil vs Gear Oil
