Brad Penn in a 3 holes?
***I hate that you can't edit the thread title. Of course I meant "all 3", not "a 3".***
No, not 20W50 in all 3.
If you were going to put BP in all 3 what would you use? I'm thinking...
20W50 in crank (of course)
80W90 in tranny
Straight 30 in primary? Or would 10W40 work better here? I'm still not sure about cold flow requirements in the primary. It seems most people that use multi-grade oils in the primary do so because they are easier to get than single grades.
80W90 in tranny
I have been using HD Formula+ in the primary, and it seems to work fine. Some use automatic tranny fluid. I have been running Castrol GTX 20-50 dino in the engine, and 75-90 gear lube in the tranny. Works great in my 99 EVO, and so far no leaks or seeps.
Good call. Totally forgot that Brad Penn's "thing" is high ZDDP for flat tappet appliations. Probably not the best for the primary. I'll stick with F+.
2006 ultra classic
Oil Archive (no new posts)
03-29-2009 04:37 PM
