81 sportster trans
81 sportster trans
Greetings
I have a 1981 sportster I fried the clutch and prior to smoking the clutch no issues. After replacing both sets of discs I now have a problem. I start off in first grabs great then shift into 2nd I feel the shift let go of clutch and nothing it is like it is in neutral reves up and not in neutral I can pull clutch up shift feel it and still neutral down shift back in first it grabs and most of the time this happens but sometimes I can make it grab all gears. At first it the clutch was not ajusted right would grab at the very end of lever release now it fully grabs in middle of lever release.
