Gear change for twin cam.
I read a email from Jerry Branch in Bill Rooks book "How To Build A Harley Davidson Torque Monster". Jerry recommends (in the early twin cams 2000 plus) dropping the motor sprocket from a 25 tooth to a 24 tooth and change the trans pulley sprocket from a 32 tooth to a 30 tooth. He said the motorcycle will run 10 times better everywhere with this setup.
I asked my local Harley mechanic and he said to change the motor sprocket from a 25 to 24 and leave it at that. He reckons if i change both sprockets as Jerry Branch recommended above, the difference won't be noticeable because that setup will counter each other.
I'm a bit unsure now what to do. Shall i fit both sprockets or just the motor sprocket?
FYI - My riding is like this......I like to cruise at highway speeds but i don't want to waste more then about 3 seconds to get there.
So shall i fit both sprockets or just the motor sprocket?
Can anyone help me with this?
Thanks in advance.
Thanks in advance.
Tell that mechanic to weld his tool box shut and go home. Each tooth you drop on the motor sprocket will increase your low end torque by 3% but it will also increase your RPM's out on the highway. The same thing with your trans sprocket, every tooth you drop is 3% more torque out of the hole but also the same increase in RPM's on the highway. They do not counter act each other. Counter acting would be dropping teeth on the trans pulley then dropping teeth on your rear pulley.
So do you think if i drop the motor sprocket from a 25 tooth to a 24 tooth and change the trans pulley sprocket from a 32 tooth to a 30 tooth i'll still have enough top end to cruise about 80mph on the open road without it revving it's guts out? Our speed limit here in New Zealand is 60mph, but hey, 80mph is a good medium
