New comp install problem........HELP!!!!!!
I just finished installing the new comp in my 09 classic. I started it up and it rattles like a can of marbles.
I am speechless........what's wrong, any comments. I am going to open the primary again is there anything I should look for?
bub
bub
I think I found the problem. The starter drive was staying slightly engaged with the ring gear......and now the story.
When I started this job I also had to replace the ring gear and starter drive (5 missing teeth on the ring gear and half of one on the starter drive). Now when I replaced the drive I made sure to remove the little ball bearing and I put it in the new drive.....BINGO I think the new drive came with a new bearing and ....duh like a dummy I doubled up on the bearing and I think that is why the drive stays out to far.......so I will tear the starter apart and check. Stay tuned......
BINGO........problem fixed to many ***** in the drive.....
