Clutch drag when hot
Early this year I installed a FM107 big bore kit and the recommended Barnett heavy duty clutch spring at the same time. Since then I've never been able to get the clutch adjusted right and when the bike gets hot the clutch starts to drag. I've done the cable and clutch pack adjustment several times and I know it's being done correctly, I've tried different fluids and still no luck. The bike seems to shift great with no clutch drag when cool, but the clutch starts dragging as soon as the bike gets hot. What gives? Any help is appreciated! Thanks guys!
dont have a dial indicator unfortunately...
Ever since this engine / clutch spring upgrade ive never been able to get it right... I'm going to take the primary cover off and do a visual inspection. After riding this weekend i started hearing a whurr'ing or mellow squeal coming from the primary while idling. Not sure what thats about but im concerned i may have bigger issues and thats whats causing the clutch to not adjust properly.
Took the entire clutch assembly off, inspected clutch bearing and measured the steels and plates with a micrometer. All are within spec. One thing I notoced was after I removed the clutch plates I spun the inner basket and the whole clutch basket seems to have a wobble while spinning the inner basket. Anyone have any experience with this? Wondering if the transmission shaft is bent... Any help is appreciated.
Installed new inner primary bearing and reassembled everything. This time I did the clutch adjustment using "clutch adjustment the easy way" thread and its working much better now. Looks like the clutch just needed a proper adjustment. Not sure why it wouldn't adjust correctly when doing it by the service manual. Oh well, it's fixed now.
scott7d
05-09-2019 03:19 PM
Smoothie54
05-04-2018 02:30 PM
