Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Oil line on '06 FLHT
Old 07-07-2015, 10:24 PM
SiggerTX's Avatar
SiggerTX
SiggerTX is offline
Default Trans Oil return line on '06 FLHT
I am working on my '06 FLHT TC88 with 5speed transmission. I have a leak at these two 90* hoses under the clutch cable cover. I ordered new hoses, the parts manual shows them to be the same hoses. When I pulled the cover the bottom hose is actually 3 parts with what looks like a vent line tied in the middle. Should I replace it with the 90* hose or reinstall the vent?
Old 07-08-2015, 09:50 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
You need the vent.
Old 07-08-2015, 11:25 AM
SiggerTX's Avatar
SiggerTX
SiggerTX is offline
Mark, thanks so much for the reply. I trust your expertise. My parts book shows both top and bottom hoses being identical, do you know when the vent was added? I thought the transmission had a vent to the primary on the top side. Any info is greatly appreciated!
Old 07-08-2015, 04:29 PM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
That vent was added by the previous owner; why, I couldn't say. The OEM vent is on the primary side; a 90* elbow in the trans upper cover connected to a vent hose. If the OEM vent is there, I see no need for the added vent in the picture. I run an all bore 107" motor (110HP/124TQ) in my old '02 FLHT with the two hoses per the parts manual and the OEM trans vent.
Old 07-08-2015, 09:07 PM
SiggerTX's Avatar
SiggerTX
SiggerTX is offline
Turns out it wasn't a vent at all! It's where the oil temp sensor is tied in.
Old 07-15-2015, 12:07 PM
djl's Avatar
djl
djl is offline
I would replace the lower hose with the OEM part and relocate the oil temp sensor to the stock location in the front of the oil pan.
Old 07-15-2015, 12:11 PM
SiggerTX's Avatar
SiggerTX
SiggerTX is offline
That's exactly what I did. Problem solved!!!
not yours
07-27-2022 06:37 AM
SiggerTX
07-08-2015 10:24 AM
zimm
11-14-2012 02:02 PM
N4SIR
04-10-2009 08:57 PM
deergrizzly
Shovelhead
05-27-2008 10:01 AM
Quick Reply: Oil line on '06 FLHT
