Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Too much fluid in primary; not enough in transmission
Old 08-02-2015, 03:58 PM
joebedford's Avatar
joebedford
joebedford is offline
Default Too much fluid in primary; not enough in transmission
I have a new-to-me 2002 FLHTCUI. While checking fluids for the first time today I noticed I have too much fluid in primary and not enough in transmission.
I'm guessing that's a bad seal on the mainshaft and the tranny fluid is migrating to the primary.
The previous owner was not mechanically inclined so maybe the levels are an error on his part and not a leaking seal. Here's hoping...
Old 08-02-2015, 06:14 PM
joebedford's Avatar
joebedford
I may have jumped to an invalid conclusion. While the transmission was VERY low, the primary doesn't appear to be high. I've topped up the tranny and I'll monitor closely.
Old 08-02-2015, 06:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
You did...
Transmission lube cannot leak into the primary.
tbob
Screamin Eagle CVO Models
09-14-2017 10:08 PM
mirrmu
02-25-2014 09:52 AM
clayharley
04-07-2010 10:00 AM
lolife
09-24-2007 04:22 PM
lomoman
09-10-2007 05:08 PM
Quick Reply: Too much fluid in primary; not enough in transmission
