Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
I found this at Grangers Bronze Bushing / Bearing 3/4" OD X 5/8" ID X 1 1/8 " long 660 BRZ 4 pcs
You are on the right track with this, I believe someone actually makes an insert
to do just what you are attempting.Just don't remember who. Check with these guys.
I used the bushing they worked fine for 8 dollars I would Change the gear but I don't have a puller or a 1 7/8 deep socket I appreciate the help thanks Mark
