Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
95 Heritage Softail transmission issues
Old 02-09-2016, 06:52 AM
Stick1982's Avatar
Stick1982
Stick1982 is offline
3rd Gear
Default 95 Heritage Softail transmission issues
Howdy y'all! I've recently purchased a 95 heritage softail. All seemed well on the test drive other than getting in to 2nd gear took some harder than normal effort. Other gears shifted fine. The following day I went to ride and now it will not go in to 2nd gear, only 1st and nutrual. Also.. I noticed a low whining sound that came amd went. Ive already checked the linkage, clutch adjustments, and primary chain adjustment. Thanks in advance!
Old 02-09-2016, 08:05 AM
chromelens's Avatar
chromelens
chromelens is offline
I would jack the rear of the bike up and dry shift the bike through the gears. If you still have problems the oil bag is easy to pull to the side on this bike without removing all the oil lines. Pull the trans top cover and examine any issues. May be a bent shift fork, worn gears, shift drum, etc. You will be able to get a good look at things with the cover off and without removing the transmission or primary.
Old 02-09-2016, 08:18 AM
Stick1982's Avatar
Stick1982
3rd Gear
Default 95 Heritage softail trans. Issues
Thank you. I will take a look tonight doing the following and report back.
Old 02-09-2016, 04:15 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Check the shift lever at the transmission, make certain it is tight on the shaft, they are notorious for coming loose and slipping on the shaft.
doc308
Shovelhead
06-06-2019 08:44 AM
big_dubbb
17
02-20-2018 10:58 AM
Stick1982
02-10-2016 05:55 PM
Johneb48
11-29-2010 04:20 PM
killer spike
08-13-2008 12:26 PM
Quick Reply: 95 Heritage Softail transmission issues
