Noise after installing SE comp
I replaced my compensator with the SE comp set up about 4 years ago (40k miles). That comp took a dump toward the end of the riding season so I replaced it with the new (bearing) style SE comp. It makes a clunking noise (worse when cold) when the idle goes below 1050 rpm. If you bring the rpm above 1200 it will never make the noise. Is anyone hearing this noise under these conditions?
