Problem adjusting Barnett clutch cable
I replaced my Street Glide stock clutch cable with a Barnett platinum +4". I had to because I installed Chubby's WO575 handlebars and I needed a longer cable. Anyway, I'm having a real hard time getting the adjustment right. I've never had a problem adjusting the stock cable on any of my Harleys. I know the procedure - do the basket adjustment first (1/2 turn out from contact) and the cable adjustment last. It's always worked for me in the past. The problems I'm having are the following:
1. The clutch pull is much harder now - the Barnett was supposed to make it easier, not harder.
2. The engagment is much more abrupt.
3. It is a lot harder to shift now than it was with the stock cable.
4. Finally, I get a loud "ticking sound" if I try to back up the bike while in gear with the clutch pulled in. It's hard for me to tell exactly where the sound is coming from because I need someone else to put their ear up next to the motor while I'm backing up the bike. If I back up the bike when it's in neutral, I don't get the ticking sound. I don't remember hearing this sound with my stock cable. It may be nothing, but I don't think that it's normal.
Anyway, I'm open for suggestions. I called Barnett and they insist that I got the right part number (698-02) for my Street Glide. To me it seems like the cable isn't disengaging the clutch all of the way. The problem is, if I change the basket adjustment for more disengagement (even just 1/2 more turn), I get slippage under load. The clutch becomes much easier to pull, and the bike shifts easier, but it slips. Has anyone else out there had problems adjusting a Barnett clutch cable? Sorry if my explanations are confusing.
Thanks,
Doug
Thanks,
Doug
