Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
My 05 WG with 26K miles sounds like I'm running a turbo when coming to a stop. I pull the clutch in and the whistle sound stops. The clutch seems ok. Looking for ideas on what this could be.
Well I first loosened up drive belt and did test run. That didn't stop what sounds like a faint siren behind me. I then re-adjusted the primary chain and that has stopped the noise!
Thanks for the tips on what to check.
