Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
3.37 gear question
Old 07-10-2010, 10:56 AM
magnoliarunner's Avatar
magnoliarunner
magnoliarunner is offline
Default 3.37 gear question
Gear Heads,
I saw a post about changing the final gear ratio from 3.15 to 3.37.
Compensating Sprocket with 24 Teeth, HD# 40269-85A and a Clutch Shell Basket, HD# 37846-99A which is a 37 Tooth Sprocket.
Does the gear change have any affect on the starter's ability to spin over the engine?
I thought I read in a post, that changing to the 3.37 gears puts more strain on the starter.
Spinning over slower like the starter is dragging? Less leverage?
I know the diameter of the gears are changed with the adding and subtracting of the number of teeth.
Do the gears mesh with the starter?
I never thought about it before.
For those that changed, did you notice any difference?
Do you have to install a high torque starter?
Thanks for your help,
magnoliarunner
Old 07-11-2010, 07:56 PM
dawg's Avatar
dawg
dawg is offline
Received 2,969 Likes on 1,718 Posts
Some year bikes used to come stock with 3.37 gearing. A good idea if you end up going with 3.37 gearing is to think about putting a 6 speed in.
Old 07-11-2010, 08:12 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by magnoliarunner
Gear Heads,
magnoliarunner
I added 3.37 gears to my last bike without any other changes. They've been in for over 5 years with no issues.
knightwolf6269
06-08-2015 08:38 PM
wamas
Wheels/Tires
05-04-2013 01:54 AM
V2Evo96
07-29-2011 05:13 PM
Fireman1501
08-08-2010 05:34 PM
relli
06-15-2009 01:13 PM
Quick Reply: 3.37 gear question
