Help with clutch
Help with clutch
I have a 08 sportster 1200c. I'm having trouble with getting the clutch out of neutral. I've adjusted the cable and adjusting screw. It helps for a couple of days. Then the problem starts again. When I changed the primary fluid, I'm seeing brass shavings. I understand hd uses a pressure plate with brass rivets and they tend to fail. I have 38,000 miles on the bike. I want to by a Barnett clutch pack, but don't know if it will work with the oem hub. Anyone with suggestions ? I'm strapped for money so I have to do it myself. (First time) or does anyone recommend something other then Barnett.
