Inspection Cover leaking
After 25k checkup by the HD Dealer, my inspection cover is leaking. Took back to HD dealer. Still leaking. I tried installing new gasket - still leaks. Is it possible for the inspection cover to be warped? 2003 Wide Glide.......
Last edited by RdTecBiker; 05-26-2013 at 11:02 AM. Reason: adding more information
Remove the cover, check it for flatness, and straighten as required.
If all else fails, throw away the gasket and use some RTV instead.
Monkeybutt2000
13
10-28-2012 11:51 AM
