chatter (06 super glide)
http://bakerdrivetrain.com/dd7
the autopsy of an inner primary bearing
So I finally gathered the tools and parts to tear into my primary and change the drive belt while it's apart (a little over 40k on the bike now). Pulled the inner primary and the main shaft bearing race is trashed. Bearing looks good, however.
I've read about the oddities of the 06 Dyna, so I'm hesitant to use a factory part. I've looked online and see a few different options from reputable manufacturers. My question is this: what bearing should I use in my inner primary?
Mark above can hook you up. They have an IPB for this: http://bakerdrivetrain.com/high-torque-bearing-kit
