1988 FXSTC tranny fitment to newer bike help?
The tapered mainshaft transmission was last used for the `89 models, `90 and later use a tapered mainshaft/clutch assembly.
The `88 has the old starter configuration, so the hole in the case for the starter mount is a different size, although this could be modified in order to use the modern starter setup.
The `88 transmission assembly would not be a sought after item for a later model bike.
c50plus
10-17-2014 03:46 PM
