primary case removal
I'm trying to remove inside primary case from 06' deluxe. I've removed the 6 bolts on the inside and the 2 bolts on the outside near the oil filter. it seems loose on the stator side (its wiggling) , but the back side (where clutch was) isn't budging at all. Is there bolts running thru the back side of the case that I'm not seeing or do I just need to pry on it a little.
Skeezmachine
10-31-2014 10:22 AM
johnharley
06-23-2012 05:55 AM
