primary case removal
Old Nov 10, 2013 | 03:05 PM
joelaccabue's Avatar
joelaccabue
Default primary case removal
I'm trying to remove inside primary case from 06' deluxe. I've removed the 6 bolts on the inside and the 2 bolts on the outside near the oil filter. it seems loose on the stator side (its wiggling) , but the back side (where clutch was) isn't budging at all. Is there bolts running thru the back side of the case that I'm not seeing or do I just need to pry on it a little.
Old Nov 10, 2013 | 03:18 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
did you remove the starter bolts?
Old Nov 10, 2013 | 03:33 PM
joelaccabue
no, I removed the starter gear, . is the starter bolted onto the primary case from the right side of the bike?
Old Nov 10, 2013 | 03:42 PM
Mi3ninos's Avatar
Mi3ninos
Yes. And difficult to remove one of the two bolts. I use an 18" 1/4 extension and an extra set of eyes to guide me to the bolt from both sides.
Old Nov 10, 2013 | 07:08 PM
joelaccabue
got it. ended up pulling the oil tank which was kind of a bitch but it made the starter easily accessible. thanks for the advice. one more question, how do I remove the plastic breather tubes that are behind air cleaner cover. do I just grab them with some pliers and wiggle them off, I tried a little bit but didn't wanna pull too hard and break them. thanks again.
Old Nov 11, 2013 | 07:51 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You need to buy a service manual. And you really should learn to use the forum properly, instead of repeating the same questions all over different sections.
98hotrodfatboy
Shovelhead
36
Sep 5, 2018 06:15 AM
joelaccabue
Nov 11, 2013 08:13 AM
MFDFF44
Aug 24, 2013 08:42 AM
hatchetman
Nov 2, 2008 10:54 PM
susanandian
Dec 22, 2007 07:20 PM
