help please.
help please.
Hi everyone. I have a 99 paughco rigid frame with a 1979 74 ci shovelhead with a 5 speed tranny off a softail. I am going to run a 180 rear wheel and im trying to figure out spacing of the wheel and offset of the sprockets and transmission. I have 1/2" spacer between the engine and inner primary and a 1/2" offset transmission plate. So do i need to also space the compensating sprocket and the rear belt drive sprocket.
Im not sure. I bought this kind of like a rolling chasis kit only not rolling. Have been told i have to space everything. I know i have to space the rear belt sprocket because right now the belt rubs the tire. I need at least 3/8" for this but 1/2" would be better cause as far as i know the tire will grow as I ride it. Just dont know what size compensating shat extention to get. Would it also be 1/2" makes sence to me that it would but im new to this.
As for your rear wheel, this is my 160, with the rear pulley installed. You can see the edge of the pulley, which to the track of the belt gives me 3/16" of clearance, between tyre and belt. That is a bit tight, so I have since added a thin spacer. To work out how thick a spacer you need on your pulley, install it on the wheel and look down the edge of the tyre, as in my photo. I suggest you use a spacer that brings the pulley out so you can just see daylight down the back of the pulley, between it and the edge of the tyre.
The tyre won't grow wider as you ride, if anything it will get very slightly narrower.
Thanks. Misfit. It is a wide frame paughco for wide rear wheel i got all kinds of room was just wondering about the spacing of the compensating shaft extention and how big of a spacer is need. Now i hear i may not need one as i can just space my rear pully out the quarter inch i need to clear the belt. My wheel will be off centre a quarter inch but i have been told that is withing tolerance. Still reserching this though
jworm1420
01-08-2014 08:41 AM
