Compensator, starter, starter clutch oh my!
#41
If you are letting up on the starter switch like the video or the one in this thread, you are causing the action. By letting up before motor gets fully running on both cylinders, you are beating up the starter parts and the ring gear. Don't do that. Real this thread including operator admitting to releasing starter before it's running. https://www.hdforums.com/forum/softa...ing-issue.html
I can understand the theory letting up to early. In my case I have not changed my starting habits on this bike or modified it in 4 yrs. My intermittent problem getting worse is such a horrible gut wrenching sound that your brain commands your finger to release the start button without having time to think about. Think finger over hot flame you pull away automatically. It has never happened on the first cold startup. It's such a horrific sound bang/clunk that you would be able to hear loudly across a soccer field that something horrible just happened to that dudes bike from anyone in the area. The sound from the videos don't do justice IMO how nasty this sound is until you hear it in person. Runs perfect once started no other noise in my case. I will be doing the starter drive or comp pending nsanerods results.
#42
#43
I assume you mast be saying yours make the noise when you have the start button held down? If so, that is not what I am talking about. However, if your battery is old and warn out with low cranking amps, as the starter draws down the voltage from load, the solenoid can loose it voltage necessary to hold starter gear in and in a way be doing what I describe. Ever now and then, mine will bang as soon as I hit the button. The only thing I can figure is the starter gear hits the ring gear in such a way that it does not slide in. It's rare but for me it does it two or three time a year.
#44
#45
#46
Hit that star button and leave it down until the bike cranks!
#47
My noise has been solved by replacing my original battery on 08 King. I was measuring 12.5 not running, 13.8 running. Dropped to 10 on starting and sometimes that awfull noise. I installed a new 13 v not running batt and saw it drop to 11 cranking over but no more noise problem, fixed for me by the battery replacement. While my voltage readings not way out of line certainly the age and available cranking amps were. I waited 5 days of riding time to ensure it was fixed before posting. Thanks to all
#48
Had the same issues on my bike. The sound is horrible and you all most can feel the pain of the motor on startup. I took the bike in and the ended up changing the compensator and inspected the clutch assembly and the tensioner. Life is good again.
Its amazing how the moco knows what parts will fail on your bike but yet will not do a recall. Just to let you know the lifters will be next from what I understand they are junk also. Mine were just recently replaced also.
