lighten diaphragm spring
That doesn't change djl's advice! You don't mention what bike and year. The devices djl mentions offer an economical solution, but an alternative is the AMP Research EZ-Pull Clutch Assist.
Depending on model year there are also 'variable clutch pressure' kits that increase clutch pressure as speed increases and use a lighter clutch spring.
I have 11/16 bore master with your actuator cover. I was very disappointed with the end result. The lever is actually a bit harder than the cable! BDL has been of little assistance. The diaphragm spring is the lightest one BDL makes...no other spring will fit, apparently it is a proprietary setup. I asked about a coil spring and pressure plate setup but they did not know how much lighter the pull would be. I am trying to find an alternative to pulling the BDL lockup out and going with a Barnett or Rivera.
Apparently you did not read the post...it is the lightest spring they offer....your humor escapes me. But it is what it is... will thank you nonetheless.
