Converting belt to chain
We have a 25 tooth transmission sprocket for that bike. You will have to get the rear sprocket elsewhere, J&P, PBI, Drag. What tooth count? Well I'm glad you asked. Your stock ratio is a 2.06 if you get a 52 tooth rear sprocket and use it in conjunction with our 25 tooth front sprocket you will have a 2.08 which is a little shorter but that is a good thing because that stock 1st gear is to tall to start with. Then you will need to get a 530 chain and you will be the envy of your neighborhood. Now get going grasshopper you are burning up daylight.
HDCrossbones09
03-16-2012 01:34 PM
