primary drain plug leak
08-21-2014, 03:10 PM
used pipe dope ,pipe tape,silicone ,still drips !!,any suggestions
08-21-2014, 03:13 PM
Pipe tape. 2 wraps and a new O-ring. Torque to spec.
08-21-2014, 03:14 PM
If it still leaks the threads in the primary are stretched and need to be addressed.
08-21-2014, 03:15 PM
Feel the back of the primary and see if it is coming out of the tranny main shaft. My guess is that it is.
08-21-2014, 03:58 PM
theres an o ring there ??
08-21-2014, 04:13 PM
08-21-2014, 05:12 PM
08-21-2014, 05:14 PM
08-21-2014, 05:15 PM
It should be 1/2-20 straight thread that normally gets Teflon and an o ring. If its tapered pipe thread then no oring.
08-21-2014, 05:16 PM
FWIW I had to Heli-Coil mine as I over tightened it. Its better than stock now.
