Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
while replacing inner primary seals and bearing on my 04 flhtcui I noticed play in the trans input shaft. is this normal or should I pull gear set out and check shaft and bearings for wear? Thanks for input.
Shouldn't be any up/down play. Prolly trap door and inner main drive bearings getting old. Doubt you would have any wear but rather time to re bearing it.
