My parts book tells me to use a 11147 o-ring for this. I'd like to know if there is something thicker out there. My inner primary is a bit beat up around the sealing edges. ('82 - '84 FLT/FXR) Thanks!
glue the shovel o ring - the evo o ring is thicker and if you try and squeeze it in it WILL brake the engine cases lip and crack it almost all the way around -- every once in a while we see that come to the shop - 600 to fix it with the cases in hand
I've been fitting the inner to the outer without one forever and just use RTV silicone in the area. I never could get them to work as I wanted them and they would always come loose and end up leaking anyway..
