Andrews A vs AB ?
Old 12-22-2014, 03:56 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Neither the A or AB..............a #2 grind will run circles around either.
If you guys are horsing around with Lieneweber cams,(we used to get $2000-2500.00 at a time from him, and set up correctly they DO make power!!)you might want to throw a degree wheel on the crank and double-check the cam. Trust me.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-22-2014, 05:20 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,568 Likes on 2,892 Posts
Originally Posted by Daves'81FLHS
When the head is off how do you tell? Would love to put a Leinweber L3S in my bike.
Thanks,
Dave
you need to remove the valve spring - then re install the top retainer and the keepers - its the travel that is the issue and the way to check it is with a vernier the L3S has .485 lift plus you want a seal sooo around .600 between the bottom if the top retainer and the top of the valve guide measured along the side of the valve stem is what you would need
that is not a cam for a novis to install the tech sheet said minor valve work and that would be a full shop with ) experence ( not a at home guy with a set of craftsman tools < not trying to down play what your abilitys are - you need a rymac machine - a valve grinder - a valve seat grinding equiptment all of it including stone shapers and pilots - you need a way to replace guides - cut the tops of the new guides for travel AND the seal - you need mid lift top retainers - extra room lower retainers and a stronger set of valve springs -- it is not for a novis even if you can do the take apart this stuff is a real shop
Old 12-23-2014, 10:24 AM
Daves'81FLHS's Avatar
Daves'81FLHS
Daves'81FLHS is offline
Thanks for the info John, May just stick with a J cam or something with less lift.
Dave
Old 02-25-2021, 07:24 AM
HDFLH82's Avatar
HDFLH82
HDFLH82 is offline
2nd Gear
Default 82?
late 1980 / early 1981 and they were different both years with different guides they were the same length one had seals and one did not
funny thing was you had to take the heads off to see what ones it had as they haphazard the engine installs so what was done to one got lost in the mix of all of them for assembly
it was stupid really - but once the guides are replaced it is all good
Anyone know if the 82's have the same valve guide clearance issues?
Old 02-25-2021, 08:17 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
You would need to become creative - using a solid lifter front exhaust easiest to check and the rear exhaust at full lift
dial indicator connected to the solid lifter and measure the amount of travel the valve guide will allow - today we set them all at .500 travel even a bit more
caution - doing it this way with out experience you can crush the valve seal going to far - but the long guide only allowed .425 lift so if its going more then that on the gage and has not stopped you - you have the later guides
Old 02-25-2021, 08:43 AM
HDFLH82's Avatar
HDFLH82
HDFLH82 is offline
2nd Gear
Default Thanks
Ahh jeesh...I ran an A back in the day in a 78 1/2...so I bought this AB for this project...of course Andrews says it's a drop in...The motor is coming apart and I'd like to give it a compression boast, balance etc...just one more thing to check. Thanks!
Ipara
05-03-2016 07:32 PM
Keithhu
05-09-2015 05:25 PM
CoalShovel82
Shovelhead
53
06-04-2014 08:50 PM
Krazilee
Exhaust System Topics
11-19-2011 12:38 AM
martin1
08-09-2008 11:48 AM
Quick Reply: Andrews A vs AB ?
