Swing arm bearing assembly
I have pulled the swing arm off to replace the bearings as there was a good 1/4 inch of lateral movement in the swing arm. I went to a local dealership and bought the bearings, races and seals. What I didn't realize is that there is something called a bearing pivot spacer on the outer side of each bearing. When I got this bike and tore it down, I don't ever recall seeing it and when I assembled it everything was good and tight with the powder coat paint on it so I never noticed the movement.
So what are these spacers, how thick are they, can I make something else work given the holidays are here and no one will be open till after the new year? The manual shows a very limited drawing of it. Does anyone have a pic and or specs on it? Help.
Randy
1974 FLH.
Randy
1974 FLH.
edit; set the preload carefully...watch for binding, or any "catch" in the movement...
They are basically a wheel spacer..in fact the seals are the same as wheel seals...I can measure one if ya like? Tho as long as the "fit" I would say they are good to go...just long enough to be able to preload the bearings without binding/bending/breaking the "ears" on the frame.
and if so he already bent the frame up rights getting the preload set to spec - he didnot have ether one in
the next post about it does not fit in with the spacers will be what now
sorry to bust your bubble there johnjzjz but all is well Ears are straight and all is well staight and true. Im a sporster man who just made the move to shovels and yes my mistake i didn't look at the book on that build. I did nt think it a mortal sin to make a mistake and or worse yet post it on here. i thouht that is what this forum was about and oh ya that 65 sporty i built just pulled 103 in the quarter mile this summer. not bad for a hack dont you think?
