Fork Oil.
Fork Oil.
When I purchased the 74-flh, the previous owner had installed an extended chrome front end. I guess he wanted it a lot higher in the front but ever since I have had this bike, when hitting a bump or small pothole etc, there is a loud rattle in the front end. The yoke bearing is good and no movement with the forks, the brake is applied sometimes so its not a rattleing shoe, but what I was thinking, was I have never checked the fork oil. I have nacelle and wind shield and all that goes with all that so pulling all that off to open the tops of the tubes is going to be a bit of a job so I was just thinking, what if I put the oil in the bottom drain whole using the same concept as putting gear oil in an outboard motors lower unit. The lower end has a hole about four inches about the refill hole that acts like a vent but more so as a level indicator. I was thinking if I use the same pump and adapt a fitting to the drain whole, I could save a ton of work. Im thinking of putting the correct amount into the pump bottle and when its out the proper amount is in. What does everyone think. Any thoughts?
randy
randy
yea the drum brake and the first disc brake forks are awful in how they ( work is the wrong word ) but the non detergent oil works real well in them - improves the ride and the rebound correct amount is important
