Sealing a gas tank... What should I use to plug it?
Gas Leak
My 84 FLH is leaking fuel around the threaded opening where the petcock threads on. It only leaks when the tanks warm up and create interior pressure. Will JB Weld or other polymers work to seal this leak?
Can I seal it by soldering on the exterior of the tank?
The paint is custom and I hate to heat the tank too much and damage the finish so I'm not even going to attempt brazing.
I know this is asking a lot of info for my very first post, but any info will be appreciated
I have used Seal-All on Exterior surfaces...Like around the Petcock, and around the Side Mounting bolts/studs.
Seal-All is available at NAPA here...No Substitutes!!!!
I remove, dry and clean the affected area...then orient the Tank so it is Flat at area to be sealed, then apply [sparingly] let dry [I wait 24Hours], then assemble and ride...
Just did another one the other day!!!! Generally lasts 2 years or so.
On another note...If you don't keep the Hole for the Petcock clear all the way to the interior...you won't be putting a Screen on yer Petcock, then you'll need an external filter...then...Well....Nothing inside the Tank for me...
I will Not , Ever, put Anything inside my Tanks again!!!
