what next - Andrews cam gear whine 77 FXE build
Just to be clear - I pressed the original Harley gear onto the camshaft - the camshaft is a new Andrews shaft - I have re-pressed it 6 times and it still has a .001 wobble to the gear - the other HD shovel cams I have in the box run true - I believe the Andrews camshaft is crap - but I'll never get my money back for the cam - I just want to ride the bike
I just recently had an Andrews undersize gear pressed onto my "A" grind cam. They did it for me a the local HD shop. No heat, just press. There are alignment marks on the shaft that get aligned with the notch in the cam gear. I guess the press fit is tight enough that slippage isn't a problem, but it seems weird that there isn't anything to keep it aligned. The notch in the cam gear looks like it would align with a key, but there is none.
The gear is .005 tight fit - I scribe the gear to line up with the timing knotch - rpessing is not the problem - it is the cam shaft that is .002 run-out - I checked a coupke HD shafts and they are under .001 run-out - I'm real disappointed in the Andrews cam - you can actually see where the grind is not symmetric at the edges of the journal - the shaft is clearly defective but their warranty is 90 days - Gary Wallace at Andrews is going to look at the cam for me and decide if they will replace it
