S&S oil pump on earlier shovelhead
After resealing my oil pump that was leaking. I found that I was using the wrong gasket. The hole close to the top that is on the S&S pump is supposedly updated. It says the block needs to be drilled using a oil pump drilling jig. My question is do I really need to do that. The extra hole appears to be leading to the pressure regulator. I have started this engine and had 40 lbs of pressure.
Fritz Franz (04-25-2022)
HOLY CRAP! I know this is a HUGE grave dig but this is the EXACT problem I am facing right now with a 1980 FLH my old man gave me.
My old man must've changed out the oil pump, I had no clue. He never drilled the pressure release hole and I can't recall the original gasket because I had to scrape most of it off.
I don't remember it leaking before I stripped it down, but hard to say because the whole lower end of the motor was sludged, perhaps he used the proper gasket and sealed that hole off completely.
Can I run this style pump without drilling my case?
I have been doing hours and hours of research, comparing pictures, gaskets, list goes on and finally Google took me across this thread and its nailed one of my headaches with this aftermarket (non S&S btw) oil pump.
The port to be drilled was only for early cone shovels 70 to 72 if I remember correctly. Shouldn't need it on the 1980
Do some reading this inst. sheet cover the older pumps too the porting the same.
https://www.sscycle.com/docs/default...il-pump-bt.pdf
My pump has an additional hole up by the relief valve that has no corresponding hole on the 1980 crank case. This pressure relief valve alteration came about after 1980, starting with the 81's.
Just curious of the consequences of not doing this step.
