Shovel heads on a Pan head engine
Old 01-22-2016, 11:42 AM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
Default Shovel heads on a Pan head engine
What would be the purpose of putting shovel heads on a pan head engine? There is a panhead for sale locally that has had that done. Would it be something that could easily be reversed? Thanks
Old 01-22-2016, 11:54 AM
PapaThiele's Avatar
PapaThiele
PapaThiele is offline
Received 2,707 Likes on 2,158 Posts
Old 01-22-2016, 12:03 PM
Greezey Rider's Avatar
Greezey Rider
Greezey Rider is offline
Received 2,493 Likes on 1,073 Posts
Panheads were a little hard to start because the intake ports were on the left side of the heads and the carb was on the right.
A longer intake manifold was required for that setup and it didn't breathe as well as the later heads with the shorter intake manifold.
I converted more than a few Panheads to Shovelheads back in the day.
Harley built a factory Pan/Shovel as well....It was called the 1966 thru 1969 Shovelhead.
62 Pan Shovel (02-23-2021)
Old 01-22-2016, 12:21 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
OK Thanks. This one is a 1950 model and really should be put back to close to original. What would I need to convert it back?
Old 01-22-2016, 12:26 PM
Greezey Rider
Head/Barrels/Pistons....In other words a new top end.
A word of advice though, If you're not sure how many miles are on the bottom end, rebuild it when you do the top end.
Old 01-22-2016, 12:34 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
And I guess an intake? The motor was rebuilt in 1990 and the shovel heads were added at that time. I dont know how many miles have been put on it but, probably not many. Its a pretty nice old bike priced at $8900.00. Does that sound reasonable for a '50 Pan ?
Old 01-22-2016, 12:36 PM
Greezey Rider
It could be reasonable or ridiculous....Depending on the condition of the bike.
I can't see the bike, so I can't give advice on the price.
Old 01-22-2016, 12:39 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
Old 01-22-2016, 12:44 PM
Greezey Rider
Nice lookin' old bike....I'd probably take a chance on it, and I agree that it ought to be put back to original condition.
Old 01-22-2016, 01:20 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
they converted the oil pump from the cast iron to the alloy and ran ( oil line out of the oil pressure switch hole to feed the top ) not the best way to do that but it works, and yes you can put it back - pricy - oem items hard to get not impossible - correct 1950 heads, intake manifold - and the carb linkert - alloy valve covers very hard to get nice oem - alloy lifter blocks another tough item to find in usable condition, it was a tank shift that one is a foot shift - the distributor is incorrect so are the handlebars - both fenders and the oil tank are re pop as well as almost all the chrome maybe a piece or two is not - 10,000 to find and restore it mechanically to correct doing it your self on the cheep over a couple years / then fenders are a 1000 a piece in original condition with the correct holes for the strips and trim / plus oem paint is 300 a quart and you need two colors and silver maybe
Quick Reply: Shovel heads on a Pan head engine
