Carb
Old 01-25-2016, 10:23 PM
baldric's Avatar
baldric
baldric is offline
Received 3,094 Likes on 649 Posts
Default Carb
just picked up a carb and signal light housings, primary insp cover for a Shovel in a deal. Just wondering if one of you old AMF era gurus could ID the carb for me? It is AMF Harley Davidson cast with #02BF T109 stamped in the body. Its complete and I assume for an FX series bike but not sure. If any leads would be nice. Thanks
Old 01-26-2016, 06:59 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
take a picture of it
Old 01-26-2016, 09:13 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
Sure sounds like a Stock Ka-sneeze Number!
I also would Have to see it.
BTW, If you want to get rid of a set of rear signal "stalks" please drop me a PM
Old 01-26-2016, 09:31 PM
baldric's Avatar
baldric
baldric is offline
Here are pics of the carb.
Old 01-26-2016, 09:34 PM
baldric's Avatar
baldric
baldric is offline
another one
Old 01-26-2016, 10:13 PM
Racepres's Avatar
Racepres
Racepres is offline
^^ yep, stock Keihin. Fairly clean one too. Generally jetted very lean due to EPA regs of the day. Is the screw directly on top of the body exposed??
Old 01-26-2016, 10:15 PM
baldric's Avatar
baldric
baldric is offline
It is
Old 01-26-2016, 10:42 PM
Racepres's Avatar
Racepres
Racepres is offline
Excellent...someone has exposed it..
Cleen it inside, try not to get Ethanol gas on the Bowl o-ring as It will swell..
I believe all of the rebuild kits are for all of the Various years and bowls..so a rebuild kit is probably not a Bad Idea.
Set up the float, tell us what jets are in it...don't loose the rubber plug over the low speed jet, and It can make you a decent Carburetor..
And Most any airbox will go on it....
Old 01-26-2016, 11:26 PM
baldric's Avatar
baldric
baldric is offline
I was actually looking to move it. Havnt had much to do with Shovels since they were still making them. Looking for a Cv carb and came across this.
Old 01-27-2016, 08:42 AM
Racepres's Avatar
Racepres
Racepres is offline
Not gonna get much for that, as most people Can't and/or Won't tune them..
They seem plentiful.
Being as it appears to be a Later one, I will tell my friend about it...but, We have plenty around here too...
Quick Reply: Carb
