nitemare rear brake bleed problem - pics
I'm still fixin cobbled up **** on the genny shovel - now I can't get the rear GMA B caliper bleed cause the mounting angle is 90 deg off stock for this caliper model - the guy must have gotten it bled out so there has to be a way - I had to disassemble it to machine reliefs in the caliper to properly clear the mounting tabs - it was actually sideways smashed up against the ribs of the caliper shell - here is a pic or the caliper from the top looking down - also a pic of the bike now
The problem is the air is collected up at the top of the pistons - I can't push the air out since the bleeder is lower than the air pocket - the air is essentially trapped above the bleeder - the trapped air is more of an issue on the outboard piston side where there is no way of displacing the air from the inlet which is also lower than normal position
This... I've had to do this exact thing numerous times with rigged up brake systems, bit of a pain in the *** but it works
