Exhaust Bolt Blues With The 72'
So I picked up a 72' about a month ago and have been tinkering with it. It was leaking exhaust up at the heads mostly in the rear but on both cylinders. It looked like the bike may have fallen over on a trailer or something because the pipes were cockeyed. Any how I took it apart to find that the front exhaust bolt had been re tapped to 3/8 and the rear was 5/16. I don't know if the threads were already kind of jacked up but am guessing they were and I managed to strip about half of the 3/8 threads out. I'm gonna get another bolt tomorrow and cut it down to where it just a little shorter than the hole. Also can a man double stack the exhaust gaskets or anything like that ? The reason I ask is the flange on the pipes doesn't fit the same all the way around. I tried tweaking on the lower bracket but after the bolt ordeal basically had to walk away for the night.
If there is enough meat in the 3/8 hole you might be able to helicoil it back to 5/16 x 18. One trick to sealing the exhaust is using one of the woven steel evo gaskets. The bolts were never meant to support the weight of exhaust. Make sure you adjust the brackets to hold the pipes in the correct position then tighten the bolt.
Look for these online or at a local old time auto parts supply house or speed shop they are called step studs , they come on a few size's and thread combo's .These and the green loctite I've repaired many a fubar shovel exhaust port in the bike. Oh another tip grab a tube of Permatex Ultra Gray and use a healthy smear around the inside of the port and on both sides of the gasket before you put it all back together making sure the rear pipe mount is straight and solid, clean off any excess, let her sit overnight and pipe should stay put. Yet to have one come back doing this.
https://store.034motorsport.com/step...mm-to-8mm.html
If you use a 10mm x 8mm step stud it may help...10mm is slightly larger than 3/8...and 8mm is almost the same size as 5/16 so it will fit the exhaust hole...you will have to use 8mm nuts.
Thanks for the replies guys. TwiZted I have been looking for those step bolts without much luck on just buying a single or two .I have tried searching using different key words and what not. I remembered you posting about them before in another thread. If your interested in selling me one or two PM me please. I think I am also gonna look around for a new mount bracket.
