Wiring a 77 low rider
Hey guys looking to rewire my 1977 lowrider fxs from scratch with turn signals. When I got it the bike was a mess electrically. Looking to do it right and nicely. Any help or diagrams would be much appreciated!
Thanks in advance,
j
Thanks in advance,
j
I have these saved...some can use them...some can't.
http://www.amraonline.com/BikePics/H...20housings.doc
http://www.amraonline.com/BikePics/HandlebarWiring.doc
Good luck.
I have done Many...LMK if you get jammed up...
By all Means...use the stock color code...it will pay off...
Good luck.
Thanks for for the help, first time doing this. Do you have any recommendations on what to use for wire or the relays?
Just regular 12wire?
Good luck.
Good luck.
I do not like non Stock Wiring...not one bit. Wouldn't work on 'em when we had our Shop!!
I don't really remember the gauge wire off hand...CRS ...
we had it by the 100 ft roll back when...
I know that we did not use the same size everywhere..Smaller in handlebars, and larger for "feed" lines..
12ga. for main power wires to the switch, headlight, circuit breakers and relays and 16ga for the rest and you can get 25' rolls of color correct wire from several sources online including ebay.
Second option would be just buying a pre wired handlebar extension loom . They are cheap enough.
All the work is done, all the wires are labeled...and you gain cool features like self canceling turn signals, and 4 way flashers.
http://www.ebay.com/itm/ULTIMA-Plus-...26.m2548.l4275
