1979 FLH bendix problem
Old 08-13-2008, 04:50 AM
HD47knuckle's Avatar
HD47knuckle
HD47knuckle is offline
Default 1979 FLH bendix problem
Whenever I try to start my bike the bendix gear wants to stay out. Then the solenoid starts to get hot. I've tried shims,no shims. The bendix gear,shaft and starter housing and solenoid arm are all new. Any ideas would be appreciated.
Old 08-13-2008, 07:02 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
low voltage on the bat can cause this problem
Old 08-13-2008, 12:21 PM
michiganlarry's Avatar
michiganlarry
michiganlarry is offline
It is probably from low battery condition. Mine will do that too if the bat is low.
Old 08-13-2008, 12:47 PM
megawatt's Avatar
megawatt
megawatt is offline
Is the roll pin installed for aligning the inner/outer primary covers? Sometimes the holes for that pin are worn. Try holding upward at the rearward end of the outer cover as you tighten it up to get the starter shaft moved up slightly; it could be the gears are pushed together too hard from the outer cover "sagging" down a little. If the pin is missing, a piece of 1/8" welding rod cut to the proper length will do.
Old 08-13-2008, 01:05 PM
frog13's Avatar
frog13
frog13 is offline
Also, make sure all your ground wires are clean and have a solid connection. A bad ground willl act the same as a weak battery.
Old 08-13-2008, 04:09 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
You said the starter shaft was new. If you put any lubrication on the worm threads that the starter bendix (pinion gear) rides on it may cause it to stick.
Old 08-14-2008, 01:02 PM
HD47knuckle
Default Bendix
Thank you all!! you have given me some good ideas to try. Appreciate it hope I can help you on a problem sometime.
pjb
Shovelhead
11
05-05-2015 04:31 PM
japel
03-21-2015 06:39 PM
j09789
06-21-2013 05:23 PM
fatboyautos
03-28-2011 06:14 AM
calex3517
EVO
05-02-2009 10:23 PM
Quick Reply: 1979 FLH bendix problem
