77 flh starter issues
Old Mar 27, 2011 | 09:41 PM
fatboyautos's Avatar
fatboyautos
Stage III
Default 77 flh starter issues
hello i am working on 77 stock flh. the starter it seems does not always crank the engine it sounds like the bendix is not hitting the clutch hub.if I jump the solenoid from the large terminal to the small terminal the starter works fine.I have replaced the bendix gear, clutch hub and inner primary and battery during the restoration, the small wire to the solenoid is getting voltage when I press the button. any suggestions? thanks
Old Mar 28, 2011 | 06:14 AM
Mike T's Avatar
Mike T
Sounds like maybe a relay in the circuit is only working periodically.
fatboyautos
Jan 26, 2025 10:05 PM
Bagger G
Shovelhead
Jan 24, 2018 10:10 PM
Bagger G
Shovelhead
Jan 22, 2018 05:52 PM
curtisldean
Jan 15, 2016 12:42 PM
pjb
Shovelhead
11
May 5, 2015 04:31 PM
