74'' with .60 over pistons?
Old 02-11-2012, 07:19 PM
shovelhead716's Avatar
shovelhead716
shovelhead716 is offline
Question 74'' with .60 over pistons?
I have a 1200 Fxe with .60 over wiseco high compression pistons. Would this be considered a 1340 now?
Old 02-11-2012, 09:13 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,922 Likes on 17,475 Posts
Well you got the bore part of it , all you have to do is find a flywheel stretcher to get that extra 1/4" of stroke needed then you have the 80" .
Old 02-12-2012, 06:47 AM
AlCherry's Avatar
AlCherry
AlCherry is offline
You kill me, dude!
I have to assume you have the heads off if you know what type and size of pistons you have. Do one more step and measure the stroke. If the stroke is under 4", it's a overbored 74. If it is 4 1/4" its a 80. If it's more than 4 1/4, it needs to be presicely measured to see what it really is.
Old 02-12-2012, 10:41 AM
shovelhead716
I had the top-end redone a couple seasons ago. It was punched out previously, so my buddy (mechanic) had to go .60 wiseco. Still have stock fly-wheel. What "cc" would this make?
Old 02-12-2012, 12:28 PM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
Default cc
The answer is 1249 cc or 76.23 ci
Old 02-12-2012, 12:34 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 47,790 Likes on 18,560 Posts
Actually there is no answer until, as others have mentioned, you find out what the stroke is.
Old 02-12-2012, 12:52 PM
sqdealgeorge
Default "assume" we all know what that's about !
if all is true orig stroke is 3.968 (74 CI ) then the cc's are as such
Old 02-12-2012, 01:48 PM
TwiZted Biker
Knew the inch's but not the CC's , nice man . Been a long time since I cc'ed a combustion chamber on one .
Old 02-12-2012, 03:59 PM
shovelhead716
Thanx for the feedback fellas. I know its a rather pointless question, but I always wondered.
Old 02-12-2012, 04:10 PM
shovelhead716
Hey i got one more ? for you shovelhead gurus. How many teeth on a "stock" rear sprocket of 1977 FXE 1200 Super Glide? Just wondering Cuz I don't have that much lo-end off the start but I have plenty of gear on the highway. Still have the stock 4 speed. Was wondering if I have a taller gear ratio. If there even is such a thing..........
Quick Reply: 74'' with .60 over pistons?
