Starting troubles
Old 10-07-2012, 08:34 AM
kvikgrip68's Avatar
kvikgrip68
kvikgrip68 is offline
Stage II
Talking Starting troubles
Hey guys
I run a shovel from 77 . Mostly stock condition all over .
Just had the inner primary off to renew front sprocket for the rear drive chain .
also put a new clutch assembly with hub in .
Now ... the problem is that the soccer wont start.
Starter spins ..... no engagement on the starting ring . After some push at the button it kinda chatters .... like a relay sound .
Battery is fully charged . solonoid is new . Starter is bolted on tight .
Also suddenly .. headlight doesnt work when turning the dashboard switch
Ignition control light does come on .Bike wont start with kickstart .
This is killing me
what the h... is wrong here ?
Old 10-07-2012, 08:52 AM
mrlexus's Avatar
mrlexus
mrlexus is offline
Double check the wiring to the solenoid, and make sure you have the plunger/starter bendix/spring assembly together correctly.
Old 10-07-2012, 01:03 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,922 Likes on 17,475 Posts
There's the starting point and check ALL the battery cable connections including the small ground wires .
daven9113
EVO
05-04-2018 08:22 AM
sarpeezy
06-12-2015 05:16 PM
jkottke58
09-16-2011 07:06 PM
dirtyboy
Ironhead
16
06-07-2009 05:45 AM
brntkndll
04-11-2009 06:02 PM
Quick Reply: Starting troubles
