smoke ..exhaust guide or ring??
I have a 72FLH stock 74cuin.I put a new set of jugs and rings about 2000 miles back and I have started seeing a little smoke from the back cilender about a week ago,not a lot just enough to notice.never on startup only after the bike has ran about 15 minuites and when I turn off the engine a stream of smoke will drift out the pipe.so I pulled the plugs and they look great,nice lite gray and compression check is 90 psi in both so I pulled of the exhaust and took a look at the exhaust valve and I could see a little oil around the stem and guide and the rest of the valve that I could see was very lite gray.I did not do any work to the heads ,valves or guides when I changed the jugs and rings......thoughts....thanks.
the blue rubber seals are a better deal all around -- johnjzjz
Drop the rear pipe and look up in the port with a mirror , the valves wet it's the guide , the guide itself is wet the guide's working loose in the head and oil is getting past when she warms up . Common on the older ones . Rear head on a shovel gets too much oil anyway and the rear exhaust is the low point so ....................
SmittyFXDL
Engine Mechanical Topics
05-09-2018 06:10 AM
