View Poll Results: How does this piston look
Need new pistons
0%
Need new pistons rings and cylinders
0%
Stop wrenching on your bike
0%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Broke exhaust stud and had to remove front head
I broke exhaust stud on front cylinder and had to remove the head on my 04 Low Rider with 50k miles. Im not sure if this is normal wear for a piston or not and was hoping someone more knowledgeable would chime in and offer advise. Im still having a helluva time getting the rear exhaust stud nut off and might end up snapping that one as well, I hope not but its not looking to good.
So with that said, is this a good time to do new pistons? If so what else would I need to have done, like cylinders sleeved etc.
I really dont have any budget for this so I cant get too crazy if it needs freshening up. Appreciate any advise on this. Thanks for your time and patience.
That oil chit is from the breather assembly.......routes the crankcase atmosphere to the intake......oil mist gets sucked in.....EPA crap.........I think you'll be fine with the way they are........you can try to clean it up but I just went through what you're going through with broken studs and left it as is as I don't want to try to clean it and end up getting crap down between pistons and cylinders.
there doesn't appear to be anything out of the ordinary going on. how is your oil consumption? if not bad, and there are no out of place noises or performance issues you should be ok putting it back together again. did you check the compression before you took it apart? if so was it in spec and both cylinders within 5%? those would be the determining factors for me.
m
m
