1982 Duo Glide Starting Issueses
Im a new member so please forgive any mistakes. I have a 1982 FL..supposedly a Duo Glide. . I am having trouble starting it. It has electric and kick start. I have changed battery, starter, solenoid, and cables It will try to turn over once in a while, not every time. Battery checks at 13.7 volts. Tried yesterday and it went clunk. never turned over. Any tips on what we might be missing? By the way...it kicks over fine and will start. Its an 80 cu in if that matters.
It's not a Duo glide, they were the 1958 to 1964 models. When they added the electric foot it became an Electra Glide.
If you remove the plugs does the starter turn the motor over? If it doesn't it may be the battery is failing. Also where the large starter shaft gear rests in the starter housing can accumulate crud and cause the gear to drag. Also if it has been rewired, did they use heavy enough wire to carry the current.
The first thing you must do is have the battery load tested. An auto parts store will do it.
Once you know you have a healthy, fully charged battery you can start trouble shooting.
Remove all the electrical connections and clean them. Battery terminals, solenoid terminals, relay terminals.
To test the solenoid contacts, touch the voltmeter probes to the solenoid posts (not the cables ), and read the voltage while cranking the starter.
You should not see more than .5 volt. Any more than this means the solenoid contacts need attention.
Stan in Birmingham ala
Electrical/Lighting/Alarm
08-19-2013 12:52 PM
1984 fxrt, won't start. i replaced the battery and the solenoid. it doesn't want to turn over. or i?
huey54moore
08-12-2007 10:44 AM
