Died while idling, now won't start.
I just got a 1972 FLH, so last night I was puttin' around the driveway a bit to get a feel for the weight and such, and I stopped and the idle was so low that if I didn't have it have it half choked it would die.. so it did in fact die a couple times. Second time, it would not start up again. So I let it sit for about an hour, and it still would not start, choked or not... so I parked it and haven't tried to starting it since last night. I'll try again after work.. any suggestions? Thanks, -Danny
I'll check that too. Weird thing is, it rode and idled fine when I brought it home. So I don't know why the carb would all of a sudden be acting up. But maybe. And that switch is a possibility
Ssso I took off the air cleaner cover, found out the filter does not fit correctly, so I ordered a new k&n air filter (thankfully Dennis Kirk is about 4 minutes away). So hopefully I can get it back together tonight. Any other suggestions as to what may be causing the low idle and then no start?
Check the simple things first. Pull the plugs to see if they fouled. They could cause low idles and hard or no start. A stock 72 FLH uses Champion J12Y plugs or equivalent. That is a short reach plug. Don't cross thread them when you put them back. Finger tight first, then the wrench.
