Anyone have a simple wiring diagram using the 72-81 style handlebar controls ?
I have a Shovel project bike which has a new set of the 72-81 style handlebar controls mounted, and I do not have any kind of diagram for them. They were display models in an Indy shop the closed.
I'd like to use these controls and as simple a wiring setup as I can get by with.
If anyone has a diagram that makes use of them, I'd appreciate it if you could link it or attach it. Thanks !
The factory service manuals have the wiring diagrams for the years they cover. It comes in 70-78 and 78 and later versions for the FX and FLH models. On my recent project I used the 73 to 81 controls and the 1968 terminal boards rather than the socket and pins used on the later bikes.
You need to get the factory service and parts manual for your bike. They will answer many of your questions.
Wiring diagram
Please email diagram to clutchcitycycles.com or josh.aaron.wilson@gmail.com I am in desperate need of assistance.
Not a Picture tho...Reading comprehension is paramount!!!
I'll get the EI [stock?]
the coil is White on the hot side along with the hot to the EI and Pink [tach] and ??? Blue with Dyna-S [for Triggers] Checking OE
Edit; looks like OE [1980+] is same as Dyna S
White from kill on handlebars and White to Ignition "box", on one side of coil, and Blue from Ignition "box" and Pink to tach, on other side.
Edit again...I guess I didn't keep track of OP vs Your Post!
Reading Comprehension...I didn't do it!!!!
No spark issue
I've got no spark, got 12v coming from the ignition to the coil but nothing out of the coil. I have a blue and a white coming from the ignition module and need to know where they land. On my 75 I have incoming on one side and out to the points on the other side. Trying to get this bike ready for a prospective buyer and would be nice to have it running when he gets there.
