82 FLT starter operating correctly
Old 08-23-2014, 02:21 PM
sci's Avatar
sci
sci is offline
Default 82 FLT starter operating correctly
I have a 1982 FLT shovel. When I hit the starter switch, the starter shrieks like an eagle (sounds like an air impact when removing a wheel lug) and then finally turns the motor over and starts. The sound is getting worse with every start.
I have replaced the starter, solenoid, and battery. I have also had everything apart and the starter shaft and all the gears look good. Any help on what my problem is would be appreciated.
Many thanks,
Dan
Old 08-24-2014, 07:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
You should have come here before you replaced the starter, solenoid etc....
It sounds like a bad starter drive unit.
Old 08-24-2014, 12:59 PM
sci's Avatar
sci
sci is offline
Many thanks Dan, I will try that.
Old 08-29-2014, 08:51 AM
sci's Avatar
sci
sci is offline
Default shovel starting problem
Last night I changed the starter drive unit and the old shovel stared perfectly. Thanks a-million Dan.
Old 08-29-2014, 11:06 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Thanks for the update.
FL54
Shovelhead
44
01-24-2018 08:31 AM
garystaven88
Electrical/Lighting/Alarm
10-25-2015 11:39 AM
hardheaded
Shovelhead
07-01-2013 12:11 AM
pedulla242
03-02-2011 11:12 PM
sunup420
EVO
02-07-2010 11:58 AM
Quick Reply: 82 FLT starter operating correctly
