2014 Fat Bob Riser Spacers or New Risers
Old 02-29-2016, 01:44 PM
Helmsy67's Avatar
Helmsy67
Helmsy67 is offline
Default 2014 Fat Bob Riser Spacers or New Risers
Hey guys I've got a 2014 FXDF and I would like to add some Riser spacers or new risers to get the bars up a little higher and by proxy a little closer for when I'm stretched out cruising. Most of the threads I've found are a bit dated and recommend Spacer Jims spacers but he's no longer in the biz. Anyone have any suggestions? I really don't want to go any higher than the stock cables and wires will allow.
Old 02-29-2016, 02:15 PM
DK Custom Products's Avatar
DK Custom Products
DK Custom Products is offline
Sponsor
DK Custom Products offers 'fat' riser extensions in 1", 2", and 3" lengths, they're 1.5" in diameter and will fit the #59783-08 risers found on your Fat Bob. The riser extensions will bring your bars up and rearward and the extensions ship with the proper length grade 8 bolts to replace the stock riser bolts.
These are 2" riser extensions on a Wide Glide running the same #59783-08 risers as your Fat Bob, still running the stock clutch and throttle cables, brake line, and wiring
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old 02-29-2016, 02:48 PM
joe40x's Avatar
joe40x
joe40x is offline
+1 for DK...They are good to go!
Old 02-29-2016, 02:50 PM
Helmsy67's Avatar
Helmsy67
Helmsy67 is offline
Thanks. I saw those while doing some research. I was worried the stock cables might not be long enough. I may just be the Guinea pig on those if no one with fat Bob chimes in!
Old 02-29-2016, 02:51 PM
Helmsy67's Avatar
Helmsy67
Helmsy67 is offline
Thanks. Probably the way I'm leaning
Old 02-29-2016, 03:04 PM
liberty911's Avatar
liberty911
liberty911 is offline
The 2 inch riser extensions won't be a problem. I have the 3 inch on my Wide Glide and my father-in-law has 2 inch on his Fat Bob. There is still a little extra wiggle room on his. DK stuff is great.
Old 02-29-2016, 03:11 PM
Helmsy67's Avatar
Helmsy67
Helmsy67 is offline
Good to hear. I agree, DK is great!
Old 02-29-2016, 03:17 PM
liberty911's Avatar
liberty911
The 2 inches make a huge difference too...That's what she said...sorry.
Old 02-29-2016, 03:19 PM
NMfxdf's Avatar
NMfxdf
NMfxdf is offline
You won't need new cables at all for those.
Old 02-29-2016, 03:25 PM
DynaKid94's Avatar
DynaKid94
DynaKid94 is offline
another +1 on the dk extensions, threw a set of 2" ones under my 8" risers as a more cost effective way to get my bars where i wanted them. height is perfect now and definitely a very solid product. i pull back on my bars a lot, for various reasons, and no issues whatsoever.
Quick Reply: 2014 Fat Bob Riser Spacers or New Risers
