Primary Cover Drain Plug
Yesterday at work I notice that my primary drain plug was leaking, just a drip or two, I had changed primary oil a couple of weeks ago, so when I got home I tried to tighten the plug, it screwed all the way in and fell into the primary, of course I lost all the oil, had to remove the primary cover to retrieve the plug, coated the plug with high temp silicone gasket maker, screwed it in until the plug was flush, let it dry, then replaced the oil. I see this as a temporary fix, but I needed to ride to work the rest of the week and then work on it some more this weekend.
Do any of you have any idea on what to do to fix the drain plug situation, it did not leak any today, riding 30 miles to work.
It looks like a standard 1/8" stainless pipe plug to me. The bike is 20 years old and I have owned it for only three of those years, I guess someone really tried tightening it. I will come up with something.
Received 4,317 Likes
Seals it up great and the plug is easy to get out when it comes time to change the fluid.
I also use teflon paste on my tranny drain and fork drains.
Works like a charm.
Yeah I know I gotta be smarter than a roll of tape but somehow it always outsmarts me an makes a mad dash for freedom!!!!!
Had the same problem ... drilled it out and tapped it to 7/16 UNF ... I use a Stainless socket head cap screw that I undercut the bottom of the head a little to hold an o-ring ... I still use Teflon tape on the threads and have not had any problems ... I did remove the outer primary cover to do the work
Mattbastard (01-24-2019)
